markaboo929
- Mooresville,NC
I have an XJ Dana 44 for sale it has all brand new bearings seals fresh Yukon gear 488 gears an Aussie Locker and 8.8 disc brake setup. All with about 25 to 30 thousand miles. It will include rear brake cables which came from Passenger Side Explorer plenty long even at the 8in lift that it currently sits at. It also has custom u bolt eliminators basically ruffstuff specialties leaf spring plate welded to the leaf spring Mount and another leaf spring plate on top with bolts. It has flush mount shock mounts on the tubes and set up for a cross Enterprises top shock crossmember so exhaust modification may be needed with the passenger side exhaust tail pipe. Also has stainless steel brake lines for the rear and diff cover guard.$750 obo.For all listed.I also have a Dana 30 High pinion with an Aussie locker and Yukon gear 488 gears as well that will become available as soon as I can get to pull it out.PM or text 828-404-9320 anytime 24/7.Can deliver to reasonable udistance free.
