XJ Dana 44 Rear Axle - Discs, Geared & Locked
XJsportG
SouthEast #4328 (RVA)
Richmond, VA
SOLD: XJ Dana 44 Rear Axle - Discs, Geared & Locked
$1000 - Richmond, VA
Shipping available, buyer pays.
- 4.56 Yukon Gears
- Yukon Grizzly Locker
- 8.8 Disc brakes w/ e-brake
- ZJ rotors
- Riddler Diff Cover W/ LubeLocker
- Barnes 4WD Leaf Perches
- 1310 u-bolt yoke
- Stock 5x4.5 shafts
Only 2 trips on the axle since being rebuilt. Less than 2k road miles. New seals and bearings were recently installed. All Timken bearings & seals for pinion and carrier when installed. No rust other than surface rust from some scarpes. Has a bent passenger shock stud. E-brake are ready to go, may need to be adjusted. Does NOT come with the e-brake cables. East Coast Gear Supply sells cables or an XJ with 8.8 disc.
28619560_10155878017848787_5816960318073870288_o.jpg 28828882_10155878017868787_7908701628049916974_o.jpg 28698528_10155878017853787_4756232897810117918_o.jpg 28827805_10155878018148787_6370952111549310007_o.jpg
