How to tear apart rear end... and get it back together.
Gridikal
Sidney, NE
Well I've never done somthing like this before, and after many many times in the water I think I need to change the diff fluid as well as check gear teeth etc. etc. How bouta rundown on how to do this. Or a link would be just as great.. Thanks
Place large drain pan under diff
Remove diff cover bolts
Remove diff cover
Splash gear oil all over everywhere....ummm....smells goooood.
Scrape off ALL old gasket material, cover and diff
Rinse diff with brake cleaner (the good stuff, not that "safe" crap)
Run bead of "Ultra-Black" on cover, follow directions on can
Reinstall cover, tighten it to "snug"
Add oil - VERY IMPORTANT!!
Rev
Remove diff cover
drink beer
drink beer
spin tire to check for chipped teeth
catch hand in carrier
swear
remove hand from carrier
drink beer
bandage hand
drink beer
Rev
Fixed it for ya...
idenify if you have a limited slip or not.. if you do you will need to add a "friction modifier" additive too.. there are so many additives on the market that i would just go to the dealer and get their product...
USE carb cleaner... NOT brake cleaner....
brake cleaner eats through your seals like nobody's business... (why pinion seals leak alot after you change the oil)
carb cleaner will dissolve the oil and is rubber safe...
so ya... use the carb stuff.. its CHEAPER too.. usually only like 89cents a can.....
nope, no posi-track... sadly
Never used carb cleaner....that crap eats paint, plastic, and everything else it hits. Always used Brakleen, never had a problem, 225K miles changes every 30K
YMMV
Rev
Drain pan? Wazzat?
:firedevil
Yeah that's why all those fish in Lake Michigan have three eyes and toes. :doh:
I'll have you know, our lovely city of the People's Republic of Illinois, has only the finest sewage system...It doesn't end up in the lake, it ends up in the basements of the poor...
YMMV
Rev
and you think brake cleaner wont eat paint??? :confused1
read on the back of brake cleaner cans... they say "not safe for use on rubber"
and there are carb cleaners that say "safe for use on rubber"
so eh.. just find the ones that say they are safe...
any solvent of the sort will eat through paint.... :doh:
Gil BullyKatz said:
Drain pan? Wazzat?
:firedevil
Nice pic....just a question though.......I've seen them b4 but what is the gear for that is next to the ring gear? Looks like a tone ring but those are usually at the wheels.
Bandage?? Semi-clean paper towel and duct tape is all you need...
it's a tone ring......sometimes the put em in the pumpkin to keep us guessing.
OK, just what is a tone ring....whats it do?:dunno:
No guessing involved... its a Ford 8.8, which has the tone ring in the pimpkin, whereas Dana axles have them out near the flanges. What requires guesswork?
A tone ring is part of the wheel speed sensor for the ABS system. Since the 8.8 has only one tone ring in the differential, it must use a 3-channel system; XJ's use a 4-channel system with one tone ring per wheel. The computer compares the values from these sensors to determine wheel lockup and apply the ABS.
