Installing power seats ?s
kemosabee
I am going to be installing some power seats in the XJ and am wondering how should I get it wired up. I currently do not have power seats. Are there usually the wires there in a 2000 to install them or do I need to run wires from the battery/relay? Any write ups or suggestions would be great. Thanks.
James
You can run a 12 gu from the batt w/inline 30 amp fuse and use it to power your pwr/w/locks. The pwr window harness just has one violet wire to the fuse block. At least on my 92. There is a write up on here I think. I added pwr everything including Greg's power lock fix, also on here, and everything works great.
