NICE! 2200 CFM Auxialliary Cooling Fan Kit for XJ
Achmed
Southeast US
Will work with ANY year XJ. This kit fits very nice and will pull WAY more CFM than the mechanical clutch fan assembly. This kit consists of:
(1) 14" curved blade 2200 CFM electric fan
(1) 40 amp relay (pre-wired)
(1) Thermostatic control switch to set when fan comes on/off (pre-wired)
(4) Push through zips to mount fan to back of radiator.
It is all pre-wired and ready to install. All you have to do is remove your clutch fan, run a power wire and a ground wire, mount the fan, mount the relay and go. I have about $120 in this kit and will let it all go for $60 shipped anywhere in the Lower 48 states.
