Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
  #346
Old July 4th, 2011, 20:36
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
Re: The Stupidist Jeep on the Planet
finally started adding floor, origanally wanted to do a subframe like vettboy but dont have the room on the drivers side, alot of issues with the atlas driveshaft and gas pedal
less floor
more floor
plenty of clearence at full stuff
Old July 5th, 2011, 03:17
beakie's Avatar
beakie beakie is offline
I am in the same boat right now, plated most of the uniframe, sending the rig off for cage work in the next week, and once I get it back I gotta put a floor in.
with all the rust I have, it should make for some interesting splatter during the welding process, or should I say interesting welding during the splatter process.
looking forward to seeing how you finish this, as I will be following suit soon enough.
Old July 6th, 2011, 20:13
ROBZ95Xj's Avatar
got the floor subframe started. got around the atlas and trans planned out in my head
Old July 7th, 2011, 18:26
beakie's Avatar
damn, are you inside my head?
same plan as I started last weekend.
are you planning on having the floor pan above the trans/t-case removable?
and what are your plans for cleaning up inside the the rails? I figured I'd wire wheel them and rattle can them and hope for the best.
Old July 8th, 2011, 04:06
ROBZ95Xj's Avatar
there will be a piece above the trans and tcase that is removable so i can pull the shifter off and acsess the top 2 tcase bolts, and i have no plan for the frame rails at the moment
Old July 19th, 2011, 18:08
ROBZ95Xj's Avatar
lack of updates was due to a nice trip to Florida, Texas and Louisiana to fistit lots-family, anyways, Floor subframe is now 95% done, tomorow i will add some pieces down the middle to tie em all together(cept the shifter ones ill just have a pices on the side) weekend will include 2x4 crossmember to replace the one under the rear seat or i just might make one from the stick of 2x2 i got left, and ill ass shock mounts and coil retiners for the frt 60 then all it will need is gears lockers and shafts installed
Old July 20th, 2011, 17:45
ROBZ95Xj's Avatar
Floor Subframe DONE!
Old July 20th, 2011, 17:54
foxwar71 foxwar71 is offline
I like it! I should do something like that to cover my big dumb t-case.
Old July 20th, 2011, 18:45
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Looks sick Rob!
What size is that? 1.5 x .120?
Old July 20th, 2011, 18:52
ROBZ95Xj's Avatar
Originally Posted by MoparManiac View Post
Looks sick Rob!
1x1x.120
Old July 20th, 2011, 18:58
Sillyfast Sillyfast is offline
That looks like some good work there, I remember when my frame rails looked like that..PITA cleaning them up
Old July 22nd, 2011, 08:07
ROBZ95Xj's Avatar
got frt shock mounts done and shocks in, upper mounts im using homemade adapter from Chris and lowers i copied Colin's setup. im only using like 9" of shock travel and the limiting straps let the coil drop out an inch wich was exactly how i wanted
Old July 23rd, 2011, 16:45
ROBZ95Xj's Avatar
started this morning making a chunk of the pass side spring hanger disapear along with some floor
then made a new piece from 3/16 plate thats also capped on the top and bottom along with being tied into the rear rocker leg
Old July 23rd, 2011, 20:53
5-Speed XJ 5-Speed XJ is offline
looking good rob
Old July 25th, 2011, 08:52
ROBZ95Xj's Avatar
got working on the driver side hanger this morning, tonight after work it will get more steel then its off to the rear hangers
this upcoming weekend should have some pretty good updates too
Rate This Thread:
Jeeps on Little Planet Pic 4WDlifeform Non-Tech / Off Topic 2 November 30th, 2011 18:36
Blowing Up a $60,000 S.U.V. To Save the Planet buzzbombxj Non-Tech / Off Topic 8 July 25th, 2008 07:19
Planet Audio 12 inch sub Feeler Skwerly SoCal For Sale 0 January 18th, 2008 13:13
Planet Audio Amplifier Opinion blaisetd Non-Tech / Off Topic 3 April 25th, 2007 12:08
The Northeast Association of 4WD Clubs Cleans our Planet for Earth Day! Kejtar Land Use Forum 0 March 21st, 2003 10:55
