The Stupidist Jeep on the Planet
Since Ross had a cool update ill do one to, had the Jeep out a few times in the past month, had a issue with the ps overheating installed a new cooler and things are better, really have had no issues only real damage has been a broken aero visor, also have abunch of tube and tomorow will be laying out a cage on bend tech pro, lastly jeep is finally makin noises and leaking fluids like a normal jeep again
i supose to keep ross happy
t storms and down pours dont stop me
a day with a bender resulted in these
stuff welded up
jeep gots a hat
b pillar bars will be mounted to rockers legs, d pillar bars will be mounted to shackle boxes, and a pilliar bars will be to the rockers, will also have a cowls bar with 2 windshield braces like colins
Damn you have alot of time and money (metal too) into this thing whoa!
It's a sweet rig - have you weighed it? It must be a frigging tank now!
he deleted the carpet, rear seat, and doors for LCOG, that easily balances out the frame plating, rocker replacements, cage, 60s, beadlocks, and big tires
i likey. full exo or hybrid?
hybrid
thanks, hasnt been whieghed yet not sure i want to either
dude the rear seat delete alone was rediculous, you should try it
been pickin away at it, been getting some much needed ot at work so less time to work on it
mounted up the a pilliars they dont line up with the roof brace bar, no biggie i made up a tube gusset
also did up the b pilliars, on the bottom there gonna mount to a chunk of 2x2 that goes between the rocker legs
did the lower mount for the d pilliar, piece of 3.16 plate stitch welded to the floor with a piece of 2x2 going through the floor welded to the shackle boxes
lastly got this tube incerts for the ends of the halo
looks good man. more or less the route i'm going. can you open your hatch with those spikes in there?
how many feet of tubing do you think you have invested?
Hatch opens fine and I've got 90ft so far I may use a stick of hrew for the windshield bars and cowl bar if I decide to do them(I just want them cause they look cool)
