Introduce You and your Jeepspeed / Prerunner
slcpunk74
UTAH
Well I just figured we could all post up a little who we are and a pic of our jeeps with a little description. If Im off base by all means delete this but I just thought it might be nice to get this forum going on a good start.
My name is Chad(wick)
I am from West Bountiful Utah
21 years old
Here is my jeep
1997
RE 4.5" lift with full packs
Soon RE drop brackets
10"x2.5" FOA's up front
16"x2.0" FOA's out back
hanemans front fenders
bfg 33x10.5x15
Re: INTRODUCE YOU AND YOUR JEEP
Well ok then
2000 cherokee
HP30 and ford 8.8 Arb's and 4.88's
RK 4-link
King 2.5's 10's
Bilstien 5125's 14's
6.5in coils
3.5 Deaver packs with a RE 1.5 roomerang shackle
241OR 4:1... for the slow days
33X10.50's
Future plans: new front and rear bumpers, ford 9in, narrowed JK HP44, roof mounted light bar, and clean up the body work a little (had bushwackers when I bought it, it's hacked to all hell) bumpstops, frame stiffeners, alot of other crap...
Looks like we are off to a good start. I ment to say only post XJs relavent to the prerunner/ jeepspeed forum, but it looks like you guys figured that out. Nice rigs!
Mike
95 XJ sport
front:
JCR prerunner bumper
2 6" procomp lights converted to HID
4.5" fabtech coils
1.75 poly spacers
hanneman flat top 6" bulge glass fenders
blown out crappy procomp resevoir shocks
fabtech lower arms
stock uppers
procomp trackbar w/ 5/8" heim at the frame end
rear:
detours USA rear bumper
RE 4" leafs
generic 2" shackles
custom OTR fabwerks rear shock hoop
14" King 2.5" prerunner series smooth body resevoir shocks
33x10.50x15 BFG Baja T/A tires (just got em on today!)
on the list:
FOA 12" 2.5 smoothbody resivoir shocks (just need to move the mounts, i already have them)
adjustable upper and lower arms
drop brackets
SYE
full cage
glass hood (have it just need to repair a crack before it goes on)
some pics:
new shoes
the hoop
Just gonna grab this from my other thread:
2000 Jeep Cherokee Sport, A/T, 4.0, 4wd.
Suspension:
  • JKS Acos Pro's with 2" Air Bumps
  • Full Traction front coil springs
  • 4.5" Alcan built Deaver stretched rear leafs
  • 1.5" JKS Boomerang Shackles
  • 12" Stroke Fox 2.0 8 way adjustable reservoir shocks (front)
  • 10" Stroke Fox 2.0 8 way adjustable reservoir shocks (rear)
  • RE HD Trac Bar and Drop bracket
  • Full Traction LCA's
  • RCX Drop Brackets
  • Custom Fabbed Energy Suspension poly rear bumps
Chassis/Drivetrain:
  • TNT 3/16" frame stiffeners
  • TMR 1/8" front frame plates
  • T&J/Currie tubular subframe connectors/stiffeners
  • OTRFabwerks Front & Rear tube prerunner bumpers
  • OTRFabwerks Rock Rails (rocker replacement version)
  • Np231 Advanced Adapters SYE installed by XJJeeper19
  • Dumped Exhaust
  • HP D30 open 3.55
  • C8.25 open 3.55
  • Centerline Telstar 15x7 aluminum wheels
  • BFG Baja T/A 33x10.50x15
Other:
  • AutoPal E-Code h4 Headlight housings
  • Hi/Lo HID conversion
  • BajaDesigns Soltek LaPaz 8" offroad lights w/ Bajahid.com HID conversion
  • Glassworks 4.5" flare fiberglass fenders
97
4.0
auto
Front:
Rubicon Express Long Arm Upgrade Kit
Deaver front coils 5.5"
XJ anti-sway bar(T&J's)
Steering Box Brace(T&J's) - not installed yet just sitting in back seat...
Billnstein 7100's
T&J's Upper Shock Mount - not installed, need a 90* elbow on my shocks for fitment
Rear:
Rustys full leafs 4.5"
RE 1.5" shackels
Crappy PORC brand shocks
Class 3 hitch
Wheels/Tires:
American Racing 15x8 forgot what back spacing was
BFG A/Ts 33x10.50x15
Engine:
Rustys K&N kit
Live Wire Ignition upgrade
Flow Master 40 series
High flow cat
Rustys tail pipe
Misc:
Hanneman 6" fenders
Rear wiper squirt gun
Im sure I forgot something but oh well...
My rig
(Pic's & product links underlined)
Basics:
2000 XJ, 4.0, AW4, 4x4, 53K miles Snow camo paint scheme (white) :rolleyes:
Suspension:
Bilstein 9100 shocks
Bilstein 9100 bumpstops
4" Coils (unknown brand)
4" Deaver Leafs
1" Shackles
Limit straps at all 4 corners
** I have Deaver Jeepspeed 5.5 coils & Prothane coil inserts and 2" shackles ready to be installed**
Axles:
Front- D30, ARB air locker, 4.56 gears, aftermarket shafts & joints. Warn diff guard. Lowered the shock mounts and tied in a skid from shock to LCA mounts.
Rear- D44, Detroit Electrac, 4.56 gears, aftermarket shafts & joints. Trussed, relocated shock mounts & bump pads.
Steering & Control arms:
Currie tie-rod & trac bar, Currie upper and lower adjustable CA's, Rancho steering stabilizer.
Wheels & Tires:
35" Yokohama Geolanders
15" Black steel wheels
Interior:
Fully caged, through the dash (saves interior space) Rear shocks also tie into the cage.
Hunsaker race seats. Drivers side mounted to stock base for electric adjustability.
5 point harnesses
CB, wire & antenna for race radio
Garmin GPS & Sirius radio
Exterior:
Fiberglass fenders
Firebird hood vents
Armor:
Custom front bumper
Belly/tranny skid
Custom rock rails
Frame reinforced at key points
Engine bay caged - ties into frame/shock mounts/front bumper
Other:
Hella HID's
UMP air filter (not installed yet)
Odyssey battery
Stainless extended brake lines
ARB air compressor
Big ass roof rack & 3- Baja Designs 8" Soltek's not currrently on Jeep.
Other stuff I'm probably forgetting.
I can't take credit for most of the build as I bought it mostly as is. If anyone knows more about this rig I'd like to know who built it. It had Jeepspeed & BF Goodrich stickers on it at some point.
~C!~
Here is mine, specs are in my sig
Here is is with my old 33's
im Ian, i live in north texas. not much for sand or dunes, but we make it work.
as for the jeep it started as this
all stock 91 2dr.
then this
then all the outcome turned into this
its mainly was a trail rig, but with some new tires, bumpstops, fine tuning, and other little things. it will make a very strong DD/do it all rig.
but mainly dd/prerunner
Hi, im John. From Costa Mesa, California
Specs
2000 XJ 4.0
NP242
LP D30 and C8.25
Wrangler MTRs 245/10/16
RE 4.5 coils
1.5" coil spacer
Bilstein 5150
JCR front bumper
JCR stage 3 tire carrier
JCR stage 1 rock sliders
Cobra CB
Custom Cat-back (flowmaster 40)
Well nobody really knows me but im going to try and start going to social gatherings..
Anyways im 19 I live in San Clemente, and I am currently attending Saddleback Community college.
Jeep: 1993 4.0 4x4 127k miles
Rubicon Express 4.5 lift with 1.5 front spacer.
Bilstien 5100s
BFG 33x12x15
D30 3.55
C8.25 3.55
Other: Front bumper not sure who makes it bought it from previous owner
Stainless steel roof rack made by previous owner
Kragen HIDs
Warn rear bumper/tire carrier
looking to do alot more to the Jeep when money allows it...
Took bumper off for short period of time
I don't have any pics of mine in its current state...under the knife again:D
96 XJ
It's got a small block ford 289, fuel injected
Art Carr C4 trans, reverse manual valve body
Atlas 2 t-case
Full cage from bumper to bumper
Custom sheet metal dash
Race radio
Itercom w/ XM
Lowrance 540C GPS
PRP seats
4 Vision X HIDs
Radflo hyd bumps all around
RE long arms, custom crossmember
National Springs (really long from a ford ranger)
Limit straps all around
Bilstein 7100s 12" front, 14" rear
Hanneman fenders and bedsides
Champion Beadlocks
36" Iroks
Why it's under the knife...
Getting a trophy truck style 4 link
trussed up 9" rear axle, 4.88s and a spool
King 16" coil over shocks.
Once I get that all done and dialed, I'm planning to put in a D44 +4" Twin Traction Beam front suspension in it with coil overs as well.
-Dan
Mine is just starting to move more towards a dual purpose. I have a lot of barren, empty desert out here in 29 Palms, and also lots of rocks and Johnson Valley.
1996 4dr 4.0 AW4
Currently with stock D30 and welded 8.25 with 3.55s.
4.5" RE coils in a RE 3.5" lift with full packs and monotube shocks
1.5" RRO spacers and shackles
3 33x12.50R15 Pro Comp MTs
1 almost bald 33x12.50R15 AT
DPG belly skid
Coming: Yukon 4.88s for the D30; D44 with 4.88's, Detroit, and alloy shafts; RuffStuff diff covers; RK 3-link; JCR pre-runner winch bumper, stage 3 rear, stage 2 sliders; Hella 500s; Smittybilt XRC10 with synthetic rope
Eventually: Good shocks, don't know what kind yet, possibly air bumps, or more likely Prothane, stroker
New to the jeepspeed thing, but loving it. I started out building the xj for mud and trails and well idk i am just heading in a different direction. I ride the Silver Lake dunes all the time and love going fast so now i am here. And my xj is a DD so i really want a better ride as well.
this is the jeep about 2 weekends ago
It curently has a 4.5" full pack rusty's lift,with homemade 2" spacers up front and rusty's 6.5" fixed LCA's and lengthened stock uppers (going to be getting adjustables from iron man), and 2" blocks in the rear (part of the trail/mud thing i am going to be getting adjustable shackles from ironman as soon as he gets them made)
I have the rusty's 4.5" shocks in the front and did in the back until the weekend of the pics. I bent and broke both rear dog bone mounts. And i just ordered some RC Nitro 9000's for the rear. (i know cheep junk, but i am 20 and am a full time student, and they are better than nothing)
I am going to be getting a set of used RE DB's off of another NAXJA member in the next few weeks. And this summer i plan on getting some bilstien 5150's for the front. I have a long way to go and wont probably ever be out in cali in the desert but live only an hour away from the dunes so i am there all the time:)
Well thats it for now.
What are you guys at 6 to 6.5" of lift running in the rear for bumpstops? mine are just stock.
thanks fellas
now i gotta go get a mafia number
me:
im chad
23 as of the 16th, been working on a baja bug for the last year. but i blew a pinion gear in the rear so its time to spend some time on the jeep again.
my jeep:
90 4.0 bored and stroked with deaver coils and leaves build mostly for chase and night races of 1/2 1600
im planning on rethinking my front skid its a bit bigger that i would like (after building it)
Im 19, live in Indiana, going to Vincennes University for Tool & Die, and CNC Programming. My Jeep is proudly my first vehicle and has been being built for 5 years now. Now sits with 6" RK springs, 4.88 gears, 8.8 rear, 35" BFGs. All body work, installs, and tube work done at home.
got any closeups of your rear fenders? how are they mounted?
looking good :D
I cut out the rear quarters and fender wells and a good section of the floor around the fender wells. I made custom wheel tubs, the fiberglass is held on with 3M Panel Adhesive, I used sheet metal screws every 2 inchs to hold the fiberglass to the body until it cured, then took out the screws and used filler to fill holes and blend in the fiberglass to the real body. I guess I need to do a buildup thread haha. Heres some pix...
I dont have any close ups of them installed but I can for sure get some if thats what you want but heres the best shot i have from the rear
Hi, I'm Richard, and live in Bakersfield, CA. My XJ has been through quite a few versions, always trying to be better as an all around rig.
'88 XJ 4.6L stroker and auto
231 t-case with 4 to 1, 2 low kit, and HD SYE
Front diff: shaved HP D44, 5.13's, Detroit, Warn chromo axles, CTM axle joints, Warn hubs
Rear diff: Tera60R, 5.13's, Detroit, disc brakes
Champion beadlocks and 37" Goodyear MT/R's
Internal and external cage front to back
Lee Mfg steering with hydro assist
Custom front bumper and Warn winch
Front suspension:
custom made 3 link mid-arm
Skyjacker 8" coils with one coil removed
Prothane insert bumpstops
Bilstein 7100 shocks
Limit straps
Rear suspension:
Bastard pack based on Chevy 1/2 ton leaves, 5" longer than stock XJ
Custom made front spring hanger, boomerang shackle
Single arm, multi-joint traction bar
Longer poly bumpstops
Bilstein 5150 shocks
This is in Baja heading to Mike's Sky Ranch
Well thought I would post up here finally.
Me I'm Baja Curt. I live in the city of Orange in Orange County, CA.
I'm a member of Regulators Racing, winners of SCORE class 8 season for 2008.
Desert racing is my passion. And being single and a sales rep gives me the freedom to attend lot's of races :)
I've been to 7 this year (well if you include Dec 31)
I always bring my camera and sometimes am in the right spot at the right time. (right CrazyJim)
Here is a link to all my pics on Flickr
http://www.flickr.com/photos/bajacurt/sets/
My XJ is my daily driver and like I said I'm a sales rep so my vehicle is my livelihood. But that doesn't mean I don't go out and run the heck out of it.
I just know when to baby it and when to get on it (MOST of the time LOL)
Right now I have a 3.5 RE lift with 33" BFG AT and the RE monotube shocks. The 3.5 RE lift and monotube shocks are a great setup for the street but too soft for the go fast stuff.
So by Friday I'll have Deaver coils, air bumps, limit straps, drop brackets and Bilstein 7100 remote res shocks in the front and JKS boomerang shackles in the rear.
Next on the list are Deaver leafs and Bilstein 7100 shocks for the rear.
I already have the shocks just saving $$$ for the Deaver leafs.
Then it will be time to cut some holes for the shocks and maybe cage the XJ.
Let's see how long this thing remains my DD ;)
Anyways here are a couple pics of the Baja XJ and I'll post up some more when the front end is done.
Hope to see you at the next race!!!
Lookin' forward to seeing her in her go fast dress Curt!
Well she's only half dressed at this point cause I still need to do her rear end.
But here is how her front looks now.
I can't wait to take her out, play a little rough with her and get her all dusty :D
