How to check readings from check engine light
Brad Klammer
Surrey, BC
Sorry for the newbie question, but how do you check to see what is setting off the check engine light???? I've checked the obvious, fluids and whatnot, but I know there is a way to decifer which sensor it is picking up. Please dont flame me, just some good advice would be appreciated
98 Grizzly edition.
Brad
you turn the key 3 or 5 times almost on and then the light will blink in series of times and that is the code. then just call autozone and they will give you a close answer on what it is.
'98 will be obd II, that process won't work. you'll need to buy, or borrow, a scantool. it will spit out the code, then you've just got to troubleshoot that particular system. i believe i heard that several autoparts chain stores are offering that service for free...
