- Camden, SC
I needed a new rear drive shaft for the ghost so I decided to cut down a front to the length I needed. I thought I would try and document this since some of you may find this helpful. Before I start let me say that this is in no way the "best" way to do it. It is in no way perfect but might help some of you in your builds. It also shows how to replace the u-joints in the double cardan on the front drive shaft. Please overlook the general disorder in my shop. I have a tenancy to get removed from projects for short times and have to return to them when time permits. SO cleaning is usually done on the whim. On to the pictures and the tear down.
You will start with this:
I secure the ds in a vice like so:
Then I will put a screwdriver under the joint and above the piece that the yoke bolts to:
Then I use a small flat head screwdriver to push the cap away from the center of the joint:
You need to be careful with the caps only if you are reusing the joints. I am cutting this down and money is tight so the plan is to reuse them:
After the cap is out it will look like this:
I then flip the DS around in the vice and remove the other cap:
Next we remove the clips for the rest of the joint:
Then I use a 6" c-clamp and a 27mm socket to press out each side:
I use channel locks to get the cap the last little bit out. If that does not work I'll use vise grips:
Other side:
Other side:
