XJ Sliders Discounts for Naxja Users
Status
Not open for further replies.
TrailHunter
NAXJA Member #1309
Red Bluff, CA
For the month of May I'm offering Naxja users (yes both members and freeloaders :D) a 30 dollar discount on our sliders. You can use it towards both the .120 or .188 wall versions. Enter the code "naxja" during checkout to cash in this oportunity. You can read more about the sliders here, https://4x4trailhunterscom.secure.powweb.com/store/index.php?target=products&product_id=1564
I don't have access to a set where I can tell you with absolute certinty. However, looking at their pics, the sliders probably will not fit. I also looked at their sliders and the center leg is not centered, which is probably to clear the pan.
It would be very easy to build a set for you with the center leg moved back.
I don't have any better pics because there isn't really a pinch seam mount like what's found on most other sliders. The square body sits flush againts the rocker panel and pinch seam and you use self drilling screws through the seam into the square body. You only loose about 1.25" of ground clearance mounting them this way and the force of an impact gets spread accross the whole rocker panel rather than 2 or three pinch seam mounts.
do you normally run a discount on the rest fo your gear or is this more a one-time type thing?
I'm planning on getting your front and rear hooks set pretty soon.
Status
