- Sanford Fl
I have a set of axles from a 96 ram 2500 i need gone.
Front is a d60 4:10 geared disconect axle. Needs pinion bearings but everthing else on the axle is solid has new brake rotors and pads
Rear is a d70 limited slip 410 gears also needs pinion bearings but all other bearrings are good also has new brakes and drums are very low mileage.
Asking $600.00 for both
Youll need help to load but i have engine boist to help
