View Single Post
  #14
Old November 9th, 2009, 00:22
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
Re: Just Another XJ on tons, coilovers, 42's, etc. Build
Justin,
As I've said before...... your fab work is simply beautiful. Sickness in steel brutha.
Question about the rear 4-link mounts on the axle in this pic:
I'm looking at this and seeing that the lower mounts have pivot points (at the joints) that's above the centerline of the axle tube/shaft.
I've not seen lower arm mounts attached to an axle that high before......
Any concern that the axle won't rotate sending the pinion upwards and possibly causing the lower arms to bind up against the upper arms - particularly when torque is applied - on an uphill climb - or similar?
Failure is not an option...... it comes standard with every Ford.
End of Watch: Jeffco: MC1, 1312 & 0369. Yucca-Man 1215...... Rest easy brothers, we've got it from here. -----
