Ultimate 88 4340 Axle Kit - Ford 8.8 Explorer C-Clip Eliminator and axles
Status
Not open for further replies.
RWKHausSupply
From now till Dec 15th, we are offering the Yukon Premium, Ultimate 88 kit.
ULTIMATE 88 31 spline axle kit 95-02 Explorer, 4340 CHROME-MOLY ( DOUBLE DRILLED). The Yukon Ultimate 88 kit eliminates the factory c-clips and converts your housing to use two 4340 Chrome-Moly bolt in axles. No welding is needed, just a little grinding to remove the factory axle seal area. The result is a super strong setup to give you years of hard use on the trail!
This Widens the 8.8 back to stock Jeep XJ/TJ width. And gives you 4340 chromoly axles with eliminating the c-clips.
FOR A LIMITED TIME
$399 (delivered to your door in most all states)
Only till Dec 15th.
Only 4 so far?
At this price and with this warranty? Oh I didnt list it I guess, my bad.
Lifetime warranty on the axles!
only 10 more days...
Currently 21$ . After the 1st of yr I can't say/ don't know till the 2nd
how does this add to your track width? if it does add width, will your stock rotors still work?? or does it go behind the backing plate?
everything is moved out bound
Status
