    More Information - Join/Renew
built my own roof rack saved a ton of loot
BayStYat
Mississippi
I decided to try and build my own rack. It was much easier than expected. I purchased a welder and gave it a shot. My weld are functional not beatiful.
total cost was $120 with paint
PzBkB23
Why didn't you use the factory nut-certs?
i thought about it but did not have a way to put a curve in the metal to mount the base to.
Didn't need a curve if you ran a base front to rear mounted to the the nutserts, and then welded standoffs to go up to the basket.....
I had planned on using both the drip rails and the factory nutserts for my rack, but so far, haven't seen enough of a need for one to make it.
