The Stupidist Jeep on the Planet
Floors!
the not completley welded in and the several gaps to fill, wich will all get done tomorow. struggling with seat mounts, i more then likely will have to have the drivers seat off set a inch or 2. also picked up a spectra shift boot from autozone wich covers the entire hole around the shifter and lastley i think im conna cut my atlas shifters and repostion em as i dislike how the have them sit
got the pass frt floor area done today, gotta finish the acsess panel for above the uca mount
then chopped up the atlas shifters, the ones that came with it bacicly put the shifters against my thigh
all back together
everything all happy
planning on whipping out seat mounts tomorow
sweeeet, shes gettin there :thumbup:
got drivers seat mount done tonight not super pretty or technacal but it will do the job
frt is some 1x1 legs
they mount to a piece of 3x3 angle that welded to everything
rear is 2 7/16 grade 8 bolts through the floor
there welded to one of the rocker legs and the floor subframe
all together
starting to look like a interior
I shoulda never sold you those seats! Everything's looking great dude, let me know if you need help with anything for a day or two
either next weekend or the weekend after i plan on havin a little party to knock out the brakes and maybee fuel system, heck maybee hook up the speakers in the seats
lack of updates was due to a nice trip to Florida, Texas and Louisiana to fistit lots-family, anyways, Floor subframe is now 95% done, tomorow i will add some pieces down the middle to tie em all together(cept the shifter ones ill just have a pices on the side) weekend will include 2x4 crossmember to replace the one under the rear seat or i just might make one from the stick of 2x2 i got left, and ill ass shock mounts and coil retiners for the frt 60 then all it will need is gears lockers and shafts installed
[/QUOTE
That must be one of those new unbreakable DS's ;) This jeep is starting to look bad a$$
you gonna herculine them floors rob?
Yes sir hoping to have that done fri eve or sat with the exception of the cargo area as I still gotta do shock hoops and fuel cell mounts
Floors look gay seat looks worse.....that is all
They look better then your "build" thread.
:D
Rob, how's the foot room around the pedals and such? I'm trying to decide if I wannna go all out like you or just patchs to clear my dumb Stak
you are not allowed to make fun of people or their rigs unless you actually know them
Everything is fine get everything in and put the frt axle to full bump and make everything clear I lost little to no foot room around the pedals
