    More Information - Join/Renew
Clayton Off-road
99XJSp
Ridgecrest
Hey all long time reader first time poster
My question is, Has anybody purchased a clayton's offroad long arm upgrade kit?
I have a 4.5" rusty off-road lift on my 99 XJ that i am going to convert to a long arm lift.
I was wondering if the products are good to go, and if anybody has installed any of their products on the XJ?
http://claytonoffroad.com/product_info.php?cPath=18_68&products_id=110
Any help on subject would be very helpful.
Thanks
Thanks
I bought the 6.5" long arm kit and installed it in November 2007. I like the square arms, even though it does not necessarily provide any actual advantage over other designs. The arms can certainly take hits. Not that it matters a lot; I always assumed I would be on them a lot, but since the install and lots of trips to Moab, I have only touched them on rocks and such a couple of times. I really like the crossmember set up it comes with. Over 2 years in, I have had no issues with any of the components of the kit. My upper bushings on the axle side go out pretty quick, but that is a characteristic of the radius arm set up in general.
My opinion - their stuff is STOUT. I would buy it again. :D
I also have their LA upgrade. I built my own lift with a mix of Rubicon Express coils, and Big Offroad leaf springs.
However, their crossmember with LCA's and UCA's is beef. I don't have any worry about damaging these pieces. It was a major upgrade over my Rusty's LA kit.
The best part about the kit, in my mind, is how easy disassembly is. I can leave the LCA's attached, and remove the middle of the crossmember to have access to my tranny/tcase etc. With my Rusty's kit, there was a lot more work involved to do this, A LOT.
However, each LA kit offers its advantages/disadvantages. For example, TNT's LA upgrade provides better ground clearance with their Y shaped long arms, as well as an integrated skid plate with their belly pan. But, again, when it comes to accessing the drivetrain, there's a lot more work involved. I'm not too concerned about the ground clearance with my arms, or my crossmember. In addition, I can always purchase skid plates from a manufacturers and keep all that protected.
If I were to do a radius arm style upgrade again, I'd go with Clayton in a heart beat as well.
HTH
Scott
