Kennedy3170
- New Jersey
I recently lifted my 98 XJ. It got a 4.5 long arm rough country lift. Sitting on brand new 32x11.5 with 15x8 procomp steel wheels. 3.55 gearing. Today was first time really driving it. Took it down the highway, doing about 65mph and the truck would jump out of overdrive. Drove about 20 miles and as soon as I slow down and get off the highway, trans fluid come out the dipstick. The previous owner did the radiator 3 years ago along with lines to the cooler.
Thoughts on my transmission fluid issue? If this is already a started conversation, can someone get me the link to it?
Few people told me I should add an auxiliary transmission cooler after the stock one.
Was also told I should just run an auxiliary cooler and skip the stock one.
I plan on checking the breather to make sure it's not clogged.
Should I drop the trans pan, change the fluid that comes out, change filter and go from there?
Thinking I should looking into regearing to 4.10s and reprogram the truck for that set up.
The truck isn't going to be strictly woods. I will be using the truck to get to and from work as well, and getting on the highway is the only way.
Thanks in advance.
Thanks in advance.
