marcusguy
- Jing Zhou, China
While I realize that something like ride quality is almost completely relative, I really don't think that my jeep rides rough. I prefer a ride that is controlled but not harsh or rough. A little firm is ok, and I think that I would still be happy with the ride if it had a little more damping. When I bought my shocks, I was worried about getting it to stiff also, but I remember when I first switch from DT3000s to the bilsteins how impressed I was with the improved ride. It didn't move around as much and seemed more supple than the DTs. Again though, relative. I would be more than happy to take anyone for a ride who is in the area and is thinking about valving choices. Won't be back in SoCal till summer though. I really don't think it would limit your rock ability any to have valving like mine or even stiffer. When I am just cruising around the desert at a relaxed pace, I disco the front anti sway bar and I fell it is just plush. In fact anything more than a relaxed pace (10mph) makes the front feel way to soft.
When I measure the 7" of up travel, that isn't including the rubber stop. I can't remember how long it is, but I think about 1.5-2". So, measuring as you did, I would have 5-5.5" of up travel, not much different from you. Many jeepspeed guys run the same lift height as I do, but with more bumpstop extension than I do. This is because they run 10-12" shocks that are 2.5" bodys and have a longer compressed length than my short bodies have. They also have 33" tires VS. my 32". That means that many of them sit in the same place in their ride height as you. You should be fine.
I'd like to see some pics of your rear box when you are all finished and have time to snap some. I will have to do the same thing soon.
I've been running the same set of bushings in the axle mount of my rear shocks for about 1.5 years now without any problem. I typically keep them aired up to 200-250 psi and it hasn't been a problem. I've been impressed with the 1/2 heim bilstein puts in standard, they are still tight. I originally got a 9/16 heim on the bottom of the front shocks and that one started clunking pretty fast. It has been swapped for a bushing also.
My dream is to eventually trim the front enough that I can take the 2" bumpstop extensions off and have the front axle stuff as far as it would stock. I would then have to run the shocks through the fender. That would give me at least 14" in the front if the droop is limited in the same place, and I've measured that I can get at least 2" more droop without doing anything extra to the front end... trackbar, steering, etc. Problem is that I don't think any lifted spring is going to have 16" of travel and still be about to compress enough to fit in the stock location when bottomed. So that means coilovers. After that, I just have to figure out what to do with the bumpstop. On the rear, I've thought about running the popular 62" long springs under the axle (with relocated eye mounts also) and shocks into the back for about 19-20" of travel, but I'm not sure if I'm serious enough for all that.
Anyways, I'll be home this summer and I am planning on attending the race Aug. 14 in barstow and most likely prerunning the afternoon before. Barstow is nice and rough and I usually break something... so you should all come
