    More Information - Join/Renew
1999 Jeep Cherokee Sport 4WD 5-speed
bjlinma
NAXJA Member #1265
Haverhill, MA
1999 Jeep Cherokee Sport 4WD, 4.0L, 6 cylinder, 142K miles.
Pictures on Craigs list here: http://boston.craigslist.org/nos/car/206208089.html
The GOOD:
5-Speed, Cold AC, power windows, power locks. Mechanically excellent. Runs great. Passed Massachusetts Emissions in July. Tires are very good. New Brake pads, rotors and drums. New clutch. New master and slave clutch cylinders. Oil changed in engine, xfercase, front and rear diffs. Radiator new last year. Blue metalic paint with gray cloth interior. No rust.
The BAD: (not too bad :) )
AM/FM with single CD but the CD doesn't work. Drivers window motor is probably going soon. Valve cover leaks oil. Drivers seat is kind of beat. Has typical parking lot dings and scratches for it's age, paint is very good. There are two small dents on the cowl from the hood opening on the highway. (Previous owner.) The plastic cowling has been replaced with a black one that is in good condition.
$3850 or bro [email protected] or call 508-574-8954
Sorry NO shipping. Must be picked up. Haverhill, MA. 01835
Still got this guy? I may be interested. Want more info, such as mialage and the usual crap. What's it got for axels? this is a 4.0?
You said no rust, does that mean NO RUST?
There is some slight surface rust underneath and in scratches and dings. Nothing bad. Easy to touchup. NO serious rust or rust-through.
I can take a couple of pictures tonight if you want.
Here are the details from the craigslist listing.
1999 Jeep Cherokee Sport 4x4, 4.0L, 6 cylinder, 5-Speed, 142K miles.
AC, power windows, power locks, AM/FM with single CD but the CD doesn't work most of the time.
Mechanically excellent. Passed Mass Emissions in July without problems.
New Brake pads/shoes/rotors/drums.
New clutch and throw-out bearing.
Blue metallic paint with gray cloth interior.
Tires have good tread.
Radiator was replaced last year.
Drivers power window just fixed. (Replaced the regulator from a 2000 XJ)
Has typical parking scratches for it's age. Paint is very good.
Ready for winter.
Still has two small problems I'm working on.
1. Button to override the passenger windows is intermittant so sometimes the passengers can't open/close there windows. Common problem. I need to remove and clean the drivers door control and check ground. there are several threads on this.
2. The intermittant setting on the wipers doesn't work. Could be moter but is probably a contact or grounding issue. I haven't dug into it yet. There are several threads on this also.
There are some pics below.
http://links.pictures.aol.com/pic?id=9a20fQwHPb7kctp-ZV7pk*f*qZ8CoRrmVrKov4xQp5Fd3Ig=&size=l
http://links.pictures.aol.com/pic?id=9a20fQwHPb7kctp-ZV7pk*f*qejKtywyrOggv4xQp5Fd3Ig=&size=l
http://links.pictures.aol.com/pic?id=9a20fQwHPb7kctp-ZV7pk*f*qQHbt4fmEmqtv4xQp5Fd3Ig=&size=l
SOLD
