- Nashville, TN
Still think I'll be best starting over from scratch and stripping this one to resell the suspension and lift parts. Toying with the idea of starting over with a ZJ. Only drawback to that is I can't reuse my axles which are re-geared and locked.
Why won't the axles work? The front is a bolt in. An Artec truss for the 8.8 fixes the rear.
Ed, I made that comment this before I did enough deep research. I can absolutely use both axles under a ZJ. I don't know about the Artec truss, but there are 8.8 ZJ weld-on bracket kits available.
