View Single Post
  #44
Old July 12th, 2010, 14:44
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Re: Radiator Fan Override Switch (The Easy Way)
Noted and fixed (I think). You could also use a relay on the battery lead, controlled by a keyed source as well, but it would be a little more work. I like fyrfytr's approach in that it lets the PCM still run things, but I don't see any issues with this since the PCM doesn't care what is or is not connected to the fan wiring.
