studiousjames
- OK
Hello there and thanks for letting me in
New to the whole thing, a member suggests i post my issue here.
Here goes.
1989 Cherokee Sport 2 Door. 1633k miles. 4.0 unmolested.
New timing chain, gears, etc. from shop 1k miles ago. All engine sensors, coil, plugs, wires, dist, cap, rotor, I have around 160 on every cylinder with less that 4 lb variance between any 2.
. All new injectors, fuel pressure reg, new pigtail ends for injectors,
new brake booster, master cylinder, calipers, shoes, hoses etc.
K....
this thing runs boss. Seriously awesome. Only issue is it keeps eating fuel pumps. New lines, all the grounds check out. no problems at all.
Tried an airtex, then Delphi pump. No good.
I saw some threads here before I joined on how to rig an external inline pump. I just need to know how many psi that pump needs to produce. It seems that the Renix needs about 40psi or so. But all the inline pumps I can find max at like 4psi?
can someone steer me in the right direction?
Thanks again for reading and adding me. This really is the very Jeep I have always wanted.....
Here goes.
K....
