Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > NAC-Fest 2008
NAC-Fest 2008 NAC-Fest 2008 will be June 19-22 at Rausch Creek Offroad Park in PA.
  #16
Old March 2nd, 2008, 07:58
krelja's Avatar
krelja krelja is offline
Re: NAC-Fest prep thread
I need to put in my SYE, dana 44, gears, new tires, currie steering, and a aussie. It's just been to cold to work on the heep alot
  #17
Old March 5th, 2008, 09:36
knuckle_buster knuckle_buster is offline
Need front shocks, parking brake could work better, and fix the annoying oil leak.
  #18
Old March 5th, 2008, 09:54
OverlandZJ's Avatar
OverlandZJ OverlandZJ is offline
NAXJA Member # 101
I spent last saturday swapping a rear main and oilpan gasket, to find out my valve cover is leaking.
Andy tells me you scored a nice XJ, lets see a pic.
  #19
Old March 5th, 2008, 11:45
vetteboy's Avatar
vetteboy vetteboy is offline
I'm finally finishing all the crap I've been putting off for the last year. This is...
- whole interior, floor, mounting stuff, etc.
- get about 1-2" more uptravel in front
---relocate front shock mounts
---add in air bumps in place of OEM bump towers
- ditch OEM steering pump and reservoir
---add TC pump and external res.
- finally swap Dodge 2500 MC in to have a solid brake pedal
- bend up some more tube for exo bars along roof & rear quarters
I also got two front fenders and a new front header panel from a junk jeep so I'm gonna swap those in while I'm at it.
Hopefully I'll get everything painted too...we'll see. It feels good to actually be working on it again instead of fixing stupid crap.
  #20
Old March 7th, 2008, 10:09
Andy in Pa.'s Avatar
Andy in Pa. Andy in Pa. is offline
NAXJA Member #180
I just had to pick on you a little...
Getting tired of using your tranny as a foot rest?
1 to 2" more uptravel?? The 25" of suspension travel you have now isn't enough?
Paint it??? Don't you dare go and make that thing all pretty.... none of us will recognize it then.
"I can get you in...."
  #21
Old March 7th, 2008, 10:26
vetteboy's Avatar
In the Nov/Dec issue of Crawl magazine there's a writeup of one of our trail rides at Rausch. In that article there's a little spot where it talks about the death of my iPod in Cumberland Valley, where it jumped out of my lap and into a spinning driveshaft. At that point I figured having a floor might be useful. (this was in mid-June).
Keeping the same amount of travel overall, just...re-proportioning it a little bit. That pesky inner fenderwell wasn't doing anything anyway.
  #22
Old March 7th, 2008, 11:26
NAXJA Member #180
I read that article, I didn't understand how that would happen until I saw your truck up close...
Jeez, its looks like we better have a "Show and Shine" area at Nac-Fest for all the freshly painted XJ's to hang out...when are you getting the "bling" wheels/tires?? (like Zach V. on BMJA...)
  #23
Old March 7th, 2008, 12:19
vetteboy's Avatar
Zach already tried to get me to buy some.
I almost had a deal worked out to trade some guy in south NJ my tires & wheels for a set of 42" Iroks on H2's...but he ran away when I sent him pics of mine. C'mon, they're not that bad...
Floor is coming along though.
Upgraded steering pump (little higher flow & pressure), bling reservoir, and some hoses and junk are ordered and on their way.
  #24
Old March 9th, 2008, 20:38
nhrocker's Avatar
nhrocker nhrocker is offline
Jackstand wheeler
Let's see...
  • shorten down pipe+replace cat converter
  • ditch front sway bar+mounts
  • flip tierod above knuckle+replace ends+add hydro assist
  • replace axle end track bar mount
  • replace outer axle seal that blew up...
  • if time/money permits- 35's and beadlocks
....oh yeah, and get it driving again!
Still not sure what it's going to take to get it drivable since I'm still not sure what's wrong. Once it warms up my next try will be replacing the entire electrical system to see if that fixes it...
  #25
Old March 10th, 2008, 13:16
gabe4 gabe4 is offline
well just got the brakes fixed one of the caliper bolt holes was stripped. Once tapped and replaced the clicking that had been driving me crazy for a year fiannly stopped. plus i got my new 5" coils I won a last year on(thanks to DPG) it ride better. Now if I can just sort out this overheating issue. Also replaced muffler it got crushed on a tree.
  #26
Old March 10th, 2008, 14:25
vetteboy's Avatar
  #27
Old March 16th, 2008, 23:13
nhrocker's Avatar
Jackstand wheeler
Originally Posted by nhrocker
Let's see...
Looks like I can add another thing to my list, swapping out transfer cases. A friend is hooking me up with a freshly rebuilt 231 with TeraLow 4:1, 2Lo kit, new chain, and AA SYE. The lower gearing sure sounds nice since it looks like if my Jeep is running I'll be borrowing Rob's new 35's for NacFest.
  #28
Old March 17th, 2008, 07:04
vetteboy's Avatar
Yay, no more death hole.
  #29
Old March 17th, 2008, 12:53
NAXJA Member #180
Nice...no more wet feet either!! Those aren't actually pinion gears, right?? I have never seen pinion gear shifter knobs before...cool....
A.
  #30
Old March 17th, 2008, 13:32
vetteboy's Avatar
Yeah they are...from some small right angle gearboxes we're rebuilding at work.
Here they are next to a quarter (crappy pic).
These particular ones came out of some small right-angle gearboxes that drive ventilation fans for incubators at a hatchery in upstate NY.
A shot of the whole new tunnel, I'll be very glad when this part of the project is over with. I'm getting sick of sheetmetal:
Got my new steering stuff too, I overheated the factory reservoir and it sprung a leak where the plastic seam is, so that crap had to go. Might as well do an upgraded pump at the same time.
Rate This Thread:
JV prep cal SoCal Chapter 19 November 19th, 2007 20:04
how does one prep the jeep for some air?? WE b GPN Modified Tech Discussion 8 April 3rd, 2006 08:54
waggy 44 prep xjoe Modified Tech Discussion 27 June 1st, 2005 22:18
Lift kit on the way need prep help JMLichner Modified Tech Discussion 8 July 10th, 2004 22:30
Trip Prep LBEXJ 2004 NAC Fest 2 June 6th, 2004 08:29
