blaisetd
- Westlake, Louisiana (Southwest)
I am shopping for chromo shafts for my HP D44 build. I had previously starting buying stuff for a waggy d44 swap to set it up for hi steer w/GM knuckles which i am now going to use on the HP. I've searched this question and am getting mixed answers. Running GM knuckles/spindle with a Ford hub and rotor which stub shaft do i need? Some say it doesn't matter others say GM stubs. One sourse i found stated the Ford lenght as 9.720" and the GM as 9.94". If you are running this set up, please let me know what you used. thanks in advance b
