Old November 6th, 2005, 19:09
CommandoXJ96's Avatar
CommandoXJ96 CommandoXJ96 is offline
Crap... accidental shift to reverse.
i was shifting back into drive from 1-2 range while going over a speed bump about 10 minutes ago, and being that im going over a speedbump i spill my water in the car cuz its sitting in that crappy 'goes-over-e-brake' cupholder that cant hold anything but cans.
i of course dont think much about the tranny and freak out and reach for the water that is moving forward with the cap barely on it; thinking i can get it without it leaking all over my carpeting.
well, i do end up shifting into reverse from probably 15 mph...maybe 20; maybe more like 5, i cant really remember.
bam. stopped. the first thing i can think to do of, as i have never thought of this before was shift into nuetral.
so then im sitting there for a couple seconds after shifting into N thinking what should i do? and I realize my engine has stalled out completely. i shift into park so i lock the key backwards and start it up again and it runs/shifts perfectly fine. there were no weird noises dureing the accidental shift or the afterwards. did i get lucky and not damage anything? or did i damage something i just cant be seen/felt/heard?
Old November 6th, 2005, 19:11
old_man's Avatar
old_man old_man is offline
Re: Crap... accidental shift to reverse.
Most autos will handle that with no problem. It happens to little old ladies all the time.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old November 6th, 2005, 19:12
87manche's Avatar
87manche 87manche is offline
it's probably fine. I've done real nasty things to automatic trannies. I imagine that the motor stalling out was probably the best thing that could have happened. You may want to drop the pan and look for metal bits in it, but if you didn't hear anysnapping or popping noises then the clutch packs probably just slipped.
Old November 6th, 2005, 19:15
thx for the responses so quick. i actually think it was midway between nuetral and reverse for a good time while i was pressing on the brake and was just closer to reverse so it locked into that. not sure since i dont have to have my thumb depressed to change from nuetral to reverse (i dont think anyways...).
Old November 6th, 2005, 19:53
bajacalal bajacalal is offline
Now, I must ask, why were you so concerned about spilling water? Was it beer? I've always thought bevarages take second priority to driving and am prepared to drop my drink in on the floor in favor of maintaining control of the vehicle.
That said, most likely youre trannys fine. Now, if you had shifted into park you may have been in for some grinding and I know someone who screwed up a manual trans shifting into reverse on the freeway- forgot its not a 5 speed?- but it was a Triumph (small POS, British).
Old November 6th, 2005, 20:34
MyJeepXJ's Avatar
MyJeepXJ MyJeepXJ is offline
Ditto... but dont think about turning it into a sport or something!!
Old November 6th, 2005, 20:50
nitrogt101's Avatar
nitrogt101 nitrogt101 is offline
I've done the same thing, just at a little higher speed, around 35-40. No damage or anything, just laid a nice pair of skidmarks. It also killed the engine and locked the key like it did to you. Nothin big. Keep Jeeping happy.
Old November 6th, 2005, 21:22
johnlv6's Avatar
johnlv6 johnlv6 is offline
I did that in an automatic rental a couple weeks back. It scared the crap out of me. I usually have my right hand on the shifter (in my manual)...doing this in an automatic didn't work out so well for me. I don't know if i was downshifting in my brain or something? .
Old November 6th, 2005, 22:02
I've done that before driving other peoples cars- except I usually manage to knock the car into neutral from drive (like you would put a manual into first) at a stoplight when it turns green and sit there, trying to find a pedal that isin't there and reving the engine.
Old November 6th, 2005, 22:06
johnlv6's Avatar
I was honestly at a complete loss as to what happened for a few seconds. I had to put it back in park and start it up again. The nasty grinding noise freaked my out...then i realized it wasn't my car (or a friends), so it was ok . Me and automatics are not a match. I've only had manuals for about 5 years now.
Old January 26th, 2006, 14:07
sfunk88's Avatar
sfunk88 sfunk88 is offline
I did the same thing before at about 50-60 mph and its driven the same and seems to be fine now.
Old January 26th, 2006, 17:53
funvtec's Avatar
funvtec funvtec is offline
now you gotta try going in reverse about 20 mph and flooring it into drive
fun stuff happens
Old January 26th, 2006, 22:28
carnuck's Avatar
carnuck carnuck is offline
Depends what trans you have. Mopar 904 or 999 can dump the reverse band when you do this.
Old January 26th, 2006, 23:42
streetpirate's Avatar
streetpirate streetpirate is offline
fun stuff happens
thats about the only way ive ever lit em up good on dry pavement. just maybe not at 20. jeez
Old January 27th, 2006, 06:54
sixdoubleseven sixdoubleseven is offline
Why was your tanny in 1-2 anyway? Were you shifting like an "auto-stick"?
Modified transfer case shift linkage. Jeff 98XJ WI Modified Tech Discussion 19 May 31st, 2007 14:39
AW4 shift behavior houlster Modified Tech Discussion 5 May 29th, 2005 23:22
4WD shift habits casm OEM Tech Discussion 1 July 28th, 2004 19:55
Gauge Cluster Swap w. Column Shift A/T comanche91 OEM Tech Discussion 0 March 30th, 2003 15:01
