Old December 8th, 2004, 14:42
BrokenXJ BrokenXJ is offline
Brake Booster? Wifes car, Help.
My wife has a 2000 Grand Cherokee, and the brakes were a little soft. The car has 70K, so I thought I would replace the Master cylinder and save myself some money.
When I disconnected the MC I heard a hissing release of pressure. I re-installed the new MC, and could not get the brakes to bleed? THe brake light is on, and I heard a air hissing from inside the car when appling the brakes. Thier is absolutely no brakes!
Is the brake booster gone?
Old December 8th, 2004, 15:02
massxj's Avatar
massxj massxj is offline
Re: Brake Booster? Wifes car, Help.
i would say the booster is gone
Old December 8th, 2004, 18:53
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Sounds as if the booster is gone, but before giving up hope you might want to take the MC off again and see if the seal between the booster and the MC somehow was either omitted or damaged. There should be an O-ring or something of the sort between the body of the MC and the booster, and the usual recommendation is to use a new one any time you replace the MC.
Brake booster questions SV1CEC OEM Tech Discussion 0 April 23rd, 2004 03:23
97 Power Brake booster and master cylinder in 91 XJ XJUSA Modified Tech Discussion 2 February 11th, 2004 08:13
Brake Booster Rod Christopher Modified Tech Discussion 1 December 9th, 2003 06:26
Brake Booster Rod Christopher OEM Tech Discussion 1 December 8th, 2003 18:03
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 15:51
