eflores
- Greg's place
Vote for one guys
demonoid369
1997 S.E. Jeep Cherokee
Front Suspension:
Rubicon Express flex joint short arm
3.5" Nth degree progressive rate coils
Standard white body shocks
Rugged Ridge double shear track bar
Front Axle:
Hp Dana30 axle
Nitro tube sleeves
Home fab LCA skids
Rear Suspension:
Upcountry bastard pack
Home fab shackle relocator
1.5" gmc shackle
S10 shocks
Rear Axle:
Chrysler 29 spline 8.25
Factory LSD
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 231
Hack n Tap SYE
Stock front drive shafts front and back
Recovery and Armor:
Factory front tow hooks
Factory front skid
Modified factory Tcase skid
Zj gas tank skid
Ruffstuff uniframe stiffener
Tires and wheels:
Stock steel jeep wheels with 1.25" spacer.
31" kumuro m/t tires.
Interior:
Front sound bar for when I'm doorless.
exterior:
Home fab steering box spacer
Home fab steering box brace
Modified early model tire carrier
iluv83vettes
1999 Limited Jeep Cherokee
Front Suspension:
OME coils and shocks
JKS upper and lower arms
JKS sway bar discos
DPG sway bar disco cables
JKS track bar
ZJ Steering
Front Axle:
Hp Dana30 axle
RuffStuff cover
Home fab LCA skids and upper control arm brace
Rear Suspension:
OME leaves and shocks
JKS shock mounts
DPG Spring plate/bump stops
Rear Axle:
RuffStuff Cover
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 242
Tom Woods heavy duty SYE and rear shaft
Recovery and Armor:
Front ARB bull bar with Warn M8000 winch
Rear JCR Vanguard with Adventure Tire Carrier
Front factory skid
Genright 30.5 gallon fuel tank with skid
HD offroad stiffeners front to rear
Tires and wheels:
Dark grey Ecco aluminum wheels
235/75x15 Goodyear Duratracs
Interior:
Factory leather
Sound deadening Peal N Seal all throughout
Head unit delete
Bluetooth to Equalizer to alpine amps
Polk 6.5" speakers
Polk MM8" sub in subthump box
iPad mini mount
other doodads:
5-90 wiring kit
Spectre cowl induction
auxillary fuse relay box
Prime 4x4 ash tray switch panel
10 gauge headlight harness with 100 watt bulbs
Future plans:
ARB lockers
WJ steering and brakes
Truss the 30
transfer case skid
demonoid369
Front Suspension:
Front Axle:
Hp Dana30 axle
Nitro tube sleeves
Home fab LCA skids
Rear Suspension:
1.5" gmc shackle
S10 shocks
Rear Axle:
Factory LSD
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 231
Hack n Tap SYE
Recovery and Armor:
Factory front skid
Zj gas tank skid
Tires and wheels:
Interior:
exterior:
iluv83vettes
Front Suspension:
JKS sway bar discos
JKS track bar
ZJ Steering
Front Axle:
Hp Dana30 axle
RuffStuff cover
Rear Suspension:
JKS shock mounts
Rear Axle:
RuffStuff Cover
Zj disk conversion
Drive line:
Stock 4.0
Stock aw4
Stock 242
Recovery and Armor:
Front factory skid
Tires and wheels:
Interior:
Factory leather
Head unit delete
Polk 6.5" speakers
iPad mini mount
other doodads:
5-90 wiring kit
Future plans:
ARB lockers
Truss the 30
transfer case skid
