Lurch
- Long Beach, CA
I replaced my stock pump with a used unit off of a 4.7 WJ. Originally I left the high pressure fitting from the XJ pump alone and had no problems. Eventually I bored out the XJ fitting to match the diameter of the WJ one as others have done because I felt no real gain in steering power with the previous setup. Now the pump whines and groans. I have bled the system with the wheels off the ground turning the wheel lock to lock numerous times until no more bubbles appear in the reservoir. After driving around for a few minutes the steering will start to groan and the fluid in the reservoir is frothy.
I’ve gathered from reading threads of others that have done the swap that the fluid cavitation is occurring for a couple of different reasons:
I have the return line plumbed to the 3/8” port in the side of the reservoir and not the ½” one on the bottom and the smaller diameter of that port could be causing the cavitation. Not sure how switching the inlet ports on the reservoir would help as the size of the line coming out of the steering box is still 3/8”.
There is air being introduced into the system somehow, possibly in the connection between the reservoir and the pump. There are no visible leaks on my pump, hoses or steering box.
The hoses coming off the steering gear or touching, this was addressed as a problem in a TSB for the WJ. Not sure how this would cause the symptoms I’m experiencing.
Any other potential causes or fixes for this problem? Last resort would be to go back to the stock XJ high pressure fitting with the smaller hole and see if that fixes the problem, but I don’t really want to do this because I’ll lose my improved steering power. There is a cooler in the system using 3/8” hose on the return line.
