I just gabbed up some rockers for my xj.
Just wondering what everyone uses so seal the welds between the sheet metal and the tubing. I didn't run a straight bead the whole way and would like to seal it so no crap gets inside the fenderwall and sill.
I bought some of that stuff the guy uses to turn a screen door into a boat, im going to use that to seal my frame rail stiffeners. Idk if that would work in your application
I got a tube of seam sealer from napa. I managed to put a decent bead down the whole sill joint, the underside overhead welds were tough though and I struggled to get good welds for any length. I figure ill seam seal all those bottom joints generously before I undercoat, bed line them. I'm paranoid of water getting behind all this stuff.
I welded that whole seam and now I'm doing a thin coat of bondo over the edge so I can have a factory looking smooth roll at the top of slider where it meets the sill
