SAFETY EQUIPMENT
SCR1: HELMETS
Helmets must be of approved by one of the following; Snell M2000 / SA2000 / M2005 / SA2005
DOT / ECE 22-05 / BSI sticker attached. Straps must have D-ring fasteners only. No snaps or
velcro will be permitted. The interior and exterior areas of the helmet must be free of defects (i.e.,
the padding must be in good condition and the exterior of the helmet must not be damaged). Best
In The Desert Racing Association strongly recommends that entrants use helmets specifically
designed for racing.
SCR2: PROTECTIVE CLOTHING
One-piece firesuits are mandatory. Two-piece suits are not permitted. The suits must cover from
the neck to the ankles and to the wrists. The suits must not have any holes, rips, and tears or be
worn thin. The suits must also be free from any petroleum-based contaminants. All suits must be
made from fire-resistant material with the manufacturer’s fire resistant rating label attached. A
minimum of a two-layer firesuit, fire resistant gloves and footwear are very highly recommended.
Best In The Desert Racing Association highly recommends that each fire suit be labeled on the
upper right chest with the entrant’s full name, blood type, allergies or other important medical
information.
SCR3: EYE PROTECTION
Shatter resistant eye protection is required for all entrants competing in a Best In The Desert
Racing Association event. Entrants whose vehicles have full windshields must have eye
protection in the vehicle with them at all times. It is highly recommended that entrants wear the
eye protection even with the windshield. It is highly recommended that entrants with removable
dentures remove them prior to competing.
SCR4: NECK BRACES
Neck braces are highly recommended for all car and truck entrants. Neck braces should provide
adequate support and have a fire-resistant covering in good or like new condition. It is highly
recommended that a neck brace made by a recognized manufacturer be worn.
