DansGreyMj
- Nuevo, Ca
I have a non disco Hp D30 Housing with 355s (no shafts or knuckles) $50
Factory 28mm swaybar with greaseable poly bushings $35
Factory 25mm swaybar with stock bushings (i still have to confirm the size) $20
RC sway bar disconnects $20
RHD Draglink for OTK, Needs one new boot, only has 300 miles on it $60
1.5 1/4wall dom Tie Rod with 1/2ton dodge ends (same as Jeep taper) comes with spare RH tre, only has 300 miles on it $60
Or 100 for the entire steering set up. also to run OTK you will need to purchase weld in inserts.
Front doors of an 87 mj, charcoal grey, No mirrors, they would be good for half doors, the seals are dried and cracked and the pass. needs a new "chain" as the last inch rusted off and prevents it from going down all the way. $40 pair
235/75 15 tire on steel jeep wheel has about 90% tread, was my spare but is now too small, can't remember the brand but it is in good shap and not dry at all. $50
Will post pics upon request, I prefer pick up, i will be able to take it to the M&G.
