Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Advanced Fabrication and Engineering
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Advanced Fabrication and Engineering If you are worried about your project still being called an XJ or MJ, this is the place for you. If you haven't ever had a slag burn or know the smell of burning flesh, tread lightly.
Old May 8th, 2011, 19:08
xj9140 xj9140 is offline
Re: The Stupidist Jeep on the Planet
Should have painted it green...to match the motor stand
Old May 8th, 2011, 19:10
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
its a friends stand, last time i borred it he asked if i could paint it so i paited it an obnoxious florecent green
Old May 10th, 2011, 21:10
ROBZ95Xj's Avatar
valve cover is on for final time, also picked up blingin chrome breather to replave broken one
also did rear main seal, oil pan is curently oil pan is off reciving paint, i may be spending a wee bit to much time on a motor that i dont expect to last longer then a year, for now i leave you with a pic of a yucky rotating assembly
Old May 10th, 2011, 21:23
Hose that shit down with some WD40. I like the chrome breather but I dont think it will clear the hood. Maybe on the back of the valve cover it would but not the front. I could be wrong.
Old May 10th, 2011, 21:42
XJLI XJLI is offline
your valve cover bolts is fancy
Old May 10th, 2011, 21:43
ROBZ95Xj's Avatar
Grade 8, that vc aint goin anywhere
Old May 12th, 2011, 17:55
eflores eflores is offline
Vc might but the bolts a few hunks of vc will still bethere
Old May 15th, 2011, 21:05
ROBZ95Xj's Avatar
i painted the engine bay
Old May 23rd, 2011, 21:08
ROBZ95Xj's Avatar
not to much going on, got new clutch/brake pedals in along with slave cyl, capped off the bottoms of one of the doors and tossed the intake/exhaust manifolds on, tomorow it will get power steer pump and this weekend will be clutch and bolt up the trans then drop it in
Old May 30th, 2011, 17:33
ROBZ95Xj's Avatar
spent a large chunk of today making a brace for the frame end uca mount, plated the frame rail with 3/16 plate the braced the mount with 2x2x.125 box tube
now off to finish the clutch install and get this motor/trans in
Old May 30th, 2011, 19:24
ROBZ95Xj's Avatar
so much for mating the trans to the motor, im missing the dowel pins, if anyone knows where to get them or the part number let me know thanks.
Old May 31st, 2011, 05:06
Dundy's Avatar
Dundy Dundy is offline
P/N: J4005418 PIN, Trans. to Cylinder Block Qty: 2
Old June 7th, 2011, 19:55
ROBZ95Xj's Avatar
i bit the bullet and bought the dowel pins from the dealer, the $7ea price tag hurt but i need to GSD
got the motor and trans together quickly, its amazing how easy it is with them outside the vechicle
was missing one of the torx bolts, but a starter bolt fits perfect
them with the help of my brother got the motor/trans in
then bolted up the slave cyl.
the heat from the day really kicked my ass, but tomorow i plan on really kickin ass and knocking alot of shit out, including welding projects even though im outta gas
Old June 8th, 2011, 05:12
Dundy's Avatar
WOO!! GSD!
Old June 8th, 2011, 05:45
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Rock n roll dude!
Jeeps on Little Planet Pic 4WDlifeform Non-Tech / Off Topic 2 November 30th, 2011 18:36
Blowing Up a $60,000 S.U.V. To Save the Planet buzzbombxj Non-Tech / Off Topic 8 July 25th, 2008 07:19
Planet Audio 12 inch sub Feeler Skwerly SoCal For Sale 0 January 18th, 2008 13:13
Planet Audio Amplifier Opinion blaisetd Non-Tech / Off Topic 3 April 25th, 2007 12:08
The Northeast Association of 4WD Clubs Cleans our Planet for Earth Day! Kejtar Land Use Forum 0 March 21st, 2003 10:55
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
