Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 11-24-2009
97Jeepers's Avatar
97Jeepers 97Jeepers is offline
NAXJA Supporting Vendor
The Ultimate Solution for Your Tie Rod Ends!
Hey folks, got a new product for your jeep, truck or other 4x4 these will fit anything that's got a 1/2 ton sized tie rod end or larger!
I've been toying around with feedback for a while on the product development forum and with a pretty good response, they are up for sale here on !
Well its a new design for a tie rod end boot. Tired of getting sand, mud water and more in your steering and having to re-grease them every time you go out wheeling? These are designed for a set it and forget it solution to that problem. Grease your tie rod ends once with a quality SYNTHETIC grease like Chevron tek-2 or similar and pull the boot around the tapered end, slide on the cap and crimp the clamp with a pair of side cutters or a cv boot clamp crimper.
Below is a crop out of my blue print I sent to the molding company so you can match up and check dimensions to see if they'll work for your application. I have these installed on the JCR 1 ton kit that I am installing soon on my XJ and they work great.
The dimensions in RED are variable, as the end cap can be cut to fit. They are molded with a 1/2" hole in the end to facilitate cutting. I will cut them out to 7/8" (the common 1/2 ton size) if you want.
<a hr
THEY ARE 59.95 for a set of four and are available in both RED and BLACK. I will be producing a size for stock sized tie rod ends in the future. so stay tuned! Just PM me and I will get you a shipped price!
97XJ 4dr 4.0L HO, AX-15, NP231, 30, 8.25, 99 intake, JKS bits and OME Lift 4 wheel Discs
NEW PRODUCT-Ultimate Tie Rod Boots! Check it out in the Vendor Advertisement forum!
Old 11-30-2009
97Jeepers's Avatar
Re: The Ultimate Solution for Your Tie Rod Ends!
If anyone wants any more information. Dealer pricing, etc. PLEASE EMAIL ME AT EcoJeep1@gmail.com
Old 12-21-2009
hagermanfolley's Avatar
hagermanfolley hagermanfolley is offline
Ordered an air tank from this vendor at Thanksgiving. It has not arrived. Contacted the Vendor who gave me a tracking number, all it says is waiting to ship. Tried contacting this Vendor again a few times, through here and e-mail. Does not respond just a heads up.
John
2001 XJ 0" lift 31" Tires. Custom front and rear bumpers.
Old 12-22-2009
Looks like my tank shipped yesterday, Thank you Ken, also got a suprise to test out, will post results when installed.
Thanks again
John
Old 12-26-2009
97Jeepers's Avatar
Remember these are designed for 1/2 ton tie rod ends, the end cap hole will accommodate your stock sized tie rod ends but the hole for the taper will need to be shimmed. I found that a small length of polyvinyl hose works great and is flexible enough. You can find it in various wall thicknesses at any home improvement store.
Thanks for the interest!
Rate This Thread:
Ultimate DD MPG CherBear Street and Performance 64 06-17-2009 16:21
Ultimate 4.0 thethinginthewoods NorthWest Chapter 28 04-07-2009 12:07
Ultimate XJ ColoradoRaptor Colorado Chapter 18 01-22-2009 19:03
ultimate adventure brian r Intermountain Chapter 16 02-20-2006 20:36
Your ultimate xj tjader Modified Tech Discussion 12 09-21-2004 06:13
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
