4.0 Swap... What years work?
ratherbcamping
South Texas
Okay, I've been reading everything I can find, but I'm still can't find the answer I'm looking for. Maybe one of you can help?
I have an 89 XJ, 4.0 and I need to replace the engine due to a crack in the block. I think the head is okay, but I haven't check anything yet. I want to stay stock if possible, but if I find a 91-95 or a 96+ engine, will it work with the stock manifolds? If not, will it work if I swap the head (after having it checked and reworked).
Like I said, stock would be best, but finding an engine that old in good condition will be tough. What would you do?
Thanks for any input.
Tom
Tom
Unless you want to go through a bunch of work, you need to stick to an '89-90 engine. The head, manifolds, and engine control system changed in '91. An '87-88 will work, but they are less horsepower than your '89.
Tom
You can get a 4.0 short block of any vintage and just swap your existing head and other pieces onto it. If your XJ's an automatic, the swap's a breeze. If it's a manual, you'll need to either enlarge the inner pilot bearing hole in the '92+ crank by 0.04" to use the 33004041 pilot bearing, or get pilot bushing 716120 from Advance Adapters
Thank you Dr. Dyno. That was the answer I was looking for. There were a lot of threads on this subject, but most were wanting to keep the newer fuel system, upgrade computers, etc. I'm not looking for more power, just building a toy for the beach and the hunting ranch. Simple is better for me.
My son has a 95 YJ and we have spent a lot of time working on it the last few years. I really enjoy the it... so I got my own toy. Oh, it is a standard, so thanks for the tip on the pilot bearing.
Tom
