Sierra Fest Minimum Requirements and Tech Inspections
blondejoncherokee
sacramento
Hi Sierra Chapter and other Chapters!
These requirements apply to the Rubicon Run Only, the other trails are shorter and easier and less built rigs can get through.
To keep things running as smooth as possible on the trail we are posting a thread on some updates to the minimum requirements we made recently.
There will always be unplanned and unexpected breakage and we cant plan for everything but we want to grab the low hanging fruit.
Please Post up on this thread or PM with any questions or concerns.
Vehicle Requirements:
CB radio, HAM, high frequency radio, something to communicate on the trail
-One locker or two limited slips.
-33" + tires (31s will be ok on a rig by rig basis depending on driver skill, rig - Please post up your build or skill if you have 31s)
-No Dana 35s
-Dana 30 - Spare front axle shafts - No 260 joints. Also have a JACK, 36mm socket, 12 pt 13mm, 1/2" drive to 3/8" adapter and a 1/2" drive breaker/ratchet if your 12pt 13mm is not 1/2" drive
-If you have a dana 30, Highly recommended to carry at least one set of spare ball joints with your spare shafts,
-Spare rear shafts if you have a 27 spline 8.25.
-tow strap
-tow points front and rear
-T-case skid.
-Appropriate gearing for tire size. For example: 31's could run stock 3.55's, 33's should have at least 4.11's, 35's should have 4.56's. Low T-case gears can make up for diff gearing deficiencies.
-Spare tie rod and drag link if you are running 33's or larger and still have stock steering.
- Do not run knowingly broken , marginal or weak parts (dont bring a clogged radiator and overheating problems , a rig with a bad alternator, that wont stay running, bad U bolts, 260 joints, or a dana 35 for example )
-Do not bring a rig with a knowingly broken/failing axle shaft, R&P , locker, tcase, trans, motor, etc(or at least dont plan to run any trails until its fixed)
-Ensure all suspension bolts are torqued to spec and all steering and suspension joints are in good shape
-Run quality U bolts , center pins, control arm, and trackbar bolts that are torqued to spec
- 4 good tires and a spare are a must (Some exceptions if you are running New 40"+ tires and carry plugs and patches but spare is recommended )
-LCA skids are highly recommended on a stock dana 30 LCA mount
Gear:
-Bring adequate tools , sensors, and parts to fix your rig for the most likely failures
-Visibly charged fire extinguisher(BC or ABC)
-First aid kit
-Adequate spare tire, Bottle jack or high lift jack, and lug wrench
-Safety belts for driver and any current passenger (belts must be worn at all times while vehicle is moving!)
-Secured battery(no bungee cords!)
Stuff that is nice to have (Highly Recommended) :
-If you care about body damage, get some rock sliders, decent bumpers, gas skid, LCA skids
-Serpentine belt (especially if you run a non-stock belt)
- spare fuel if you are unsure
-spare ratchet straps
-Know how to work on your rig and know its limits
We are asking incredibly minimal requirements to keep a run of 15-30 rigs moving at a decent pace over 7 days with minimal breakage through the Rubicon. Obviously less built rigs can get through the Rubicon but we have the minimum requirements to keep it moving.
