Bolt In Jeep JK Tie Rod Kit!
Dan Fredrickson
Sacramento, CA
For years now we have been making Steering kits that you weld yourself. Ours have been acclaimed as the highest quality and strength with 1 glaring problem to many people! You had to weld it yourself or have a shop install it for you at a high cost...
Not anymore :)
In April we quietly introduced a ready to go welded version of the kit many of you are using! It has the same 1.5" x .25" wall DOM tubing and our 1 ton offset TRE's with the welding requirement already done by our professional welders so you don't have to. It is truly plug and play!
This is yet another of our new plug and play parts. We have been the best at making Fabrication Parts for many years and its time we stepped out of that mold a bit ;)
http://www.ruffstuffspecialties.com/catalog/JKTIEROD.html
What I see being great about this kit is that you don't have to worry about welding the wrong inserts into the wrong tubes because you don't realize that the heims for the track bar are a different thread pitch than the drag link TRE's. At least now I have a couple of "tire checkers".
