JK REAR D44 Axle assembly Complete caliper to caliper - 200$
RWKHausSupply
I have a 2012 JK rear axle assembly that is complete minus a few caliper bolts. still has oil in it and all stock. believe its 331 ratio. Been holding on to it to long.
Can be converted to use in many other rigs. Large tubes, larger gear set then the older D44's. Can put any typical D44 locker in to it. 5x5" bolt pattern currently but you can convert to 5x5.5 if needed.
200$.
located in Yorba Linda
Robert
714-875-2414
Wish you were closer and I had the cash
Very low. Idk exactly. But pulled from a 2012 about 8 months ago... would guess about 10k max...
