Jeep XJ Gear Packages!! Get In Gear!!
Just Differentials
Differentials and Axles!
Washington State
At JustDifferentials we offer top quality aftermarket Gears, Axles,
and Lockers for your Jeep Cherokee
Anyone who's taken their XJ offroad knows how demanding it can be on your axle setup.
What's one of the most important things to consider when you are rolling big tires?
Gear Ratio...
If you are an avid offroader, or daily drive on oversized tires, you will benefit by using the proper gear ratio. Let us help you upgrade your axles!
You can check out our line of XJ Gear Packages below:
http://www.justdifferentials.com/Cherokee-XJ-Gear-Packages-s/2640.htm
