how tall are you? (lifted 84-96 XJ's)
BigOrangeXJ
Norwich, CT
I am currently debating whether I want to lift my '88 cherokee 6.5" with 35's or 8" w/ 36's, but before I do anything, I should find out how tall I will end up because I want to still fit in the parking garage at work, and I don't know if that will be possible with 8" and 36's, so if you are lifted between 5.5" and 8" on your '84-'96, can you tell me how tall you are to the highest point on your roof (not including any aftermarket roof racks, etc.) and exactly what your lift setup is (height/brand/spacers?) and tire brand and size.
Thanks much for the help.
94 with Full Traction 6 inch long arms and 35 Baja Claws (bias).. Height to the top of the stock roof rack cross bars is 6'4.
Hope this helps
Kent :roll:
a true 6" over stock 38x12.50 TSLs at 5'10" at the tallest point Keep it low............. trim a bit and use the correct bumpstops
You can run 35-36's with a 5.5-6.5" lift easily, no need to go higher
