Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor's Specials
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 13th, 2017, 08:41
RWKHausSupply's Avatar
RWKHausSupply RWKHausSupply is offline
NAXJA Supporting Vendor
Currie 9" Rear axle assembly - Complete any ratio
Currie 9+ Heavy Duty axle with your desired gear ratio and with many options available.
This is a complete kit. The 3rd member is setup & ready to bolt in, the axle shafts are ready to slide in, and spring perches ready to be set for your exact pinion angle.
Click here to go to site / item
Features the 9-Plus heavy duty housing and 31 spline performance axle package built to the stock overall width and pinion offset specs. of the vehicle. Heavy duty 2 1/4 wide leaf spring pads and XJ specific shock mounts are included with the unit and must be set to spec. by the customer and welded at time of installation. Housing includes all 3rd. member studs installed and the Torino style late model large bearing housing ends. Axles include the 5 on 4 and 5 on 5 wheel bolt patterns drilled in them, and wheel studs installed in the stock 5 on 4 pattern, thick heavy duty bearing retainer plates, and tapered Timken style wheel bearings pressed on. This unit will allow for the use of many brake kits, including the 11 drum brakes, 11 Ford Explorer disc brakes, or Wilwood disc brakes. Unit is 60.625" wide (Stock).
Then you get one of the strongest 9" Assemblies you can buy. All Yukon heavy duty parts. These are ran in numerous off road competition rigs around the world.
Yukon Extra HD 3.062" Nodular Iron Dropout
Nodular Daytona Style Pinion Support
Yukon high performance gear set
Yukon Master kit used in assembly all Timken bearings
Yukon forged 1310 yoke
Yukon locker of choice
Above with Grizzly mechanical locker - $2399
Above with Zip air locker - $2699
Add:
Explorer disc brake kit(complete w soft lines) + $470
REM finish (polished) gear set (requires no break in, cooler running) + $45
This is by far, stronger than any of the Ford 8.8 or XJ Dana 44 swaps out there. And all NEW. No past owner issues.
Robert
RWK Haus Supply
Robert@RWKHausSupply.com
714-875-2414 (call or text)
RWK Haus Supply
All your drivetrain And Jeep needs at a Discount! Call us for all your drivetrain & Jeep accessorry needs. If it is for a Jeep we can get it for less and with superior service. Yukon, USA Standard, Motive, Ten factory, Detroit, ARB, Teraflex, Rock Krawler & A LOT MORE..
All items ship FAST! ~ http://www.rwkhaussupply.com ~ Robert@RWKHausSupply.com Free shipping on Rock Krawler kits. Dana 30 no question asked 1yr warranty axle kits FOR LESS!
Rate This Thread:
REAR AXLE / Chrysler 8.25" 3.55 Ratio PhotographerMike SoCal For Sale 0 June 12th, 2017 14:56
WTB Chrysler 8.25 rear axle assembly - 3.55 ratio ERobinson88 MWC For Sale/Wanted Forum 2 September 7th, 2014 16:03
JK REAR D44 Axle assembly Complete caliper to caliper - 200$ RWKHausSupply SoCal For Sale 4 November 27th, 2013 20:47
Currie rockjock front full one ton axle assembly and 14b full rear and beadlocks/gy RWKHausSupply SoCal For Sale 7 August 23rd, 2013 14:38
Currie HP 9 rear axle assembly in NJ magoo117 For Sale: Private Party Only. XJ ITEMS ONLY 0 April 3rd, 2004 16:14
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
