xj-grin
NAXJA Member #1096
- Colorado Springs, Colorado
So the Dakota died on me, "no bus" in the odometer... did diagnostics on some sensors and decided it was the PCM. Found one at a local yard for a fair price, swapped it in - starts right up (no bus problem appears solved), but dies 2 seconds later. Code P1686, which is a no SKIM bus. Appears my replacement PCM came from a vehicle that had SKIM (rf coded keys), mine does not. I'm seeing if the yard owner has a key for the vehicle this came out of, as that would be the easy fix - what else can I do as far as getting the PCM to work? Can it be done or do I need a different non-SKIM computer?:sure:
