RuffStuff 3 Link Kit!
Dan Fredrickson
Sacramento, CA
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat & Cryo Treated Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs and another set of the same in 7/8" for the Panhard. We add our Chassis Link Brackets, a 10 degree Adjustable Axle Link Tower, a 10 degree Adjustable Frame bracket for the 3rd link, the Axle Lower Link brackets. We finish the Kit off with the Panhard setup, an Axle Offset panhard Bracket & the Frame panhard (Inside or Outside).
We do not include the tubing because you will save alot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot! If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
These are $573 and $23 to ship, sound fair to you?
