front winch bumper, rear or-fab bumper, lift blocks, rear U-bolt plates with bumpstop
Empty_Pockets
Jim Thorpe
Front winch bumper. It started out as a warrior products front bumper.
http://4x4bumperstore.com/i-1287898...-CWfd5Ez_9aNby7V4ePi5YaR0OjNBhUKoEBoCUlTw_wcB
Has been modified for winch and a hoop with light hoops has been added. $300 frame ties also included.
Also or-fab rear tube bumper forsale, will have pics later tonight. $300
Creepie fab u-bolt plates, made by Naxja member Hammered, Extended to act as bump stops. $50
3 in lift blocks with u-bolts. $20
Aw4 trans from 99 175k on it shifted perfectly. $150
They should work with the 5/8" U-bolts. I have the same u-bolt plates on my D44 with 5/8" ruffstuff U-bolts. I did open the holes up a bit, but it shouldn't be an issue, even with a 3" axle tube.
front winch bumper, rear or-fab bumper, lift blocks, rear U-bolt plates with ...
Where in south jersey? I might be interested in the front bumper
Would you happen to have any better pic of the front bumper? It's a little dark in pic and was looking for a certain look, and you said yours is modified...also any pic of the rear bumper, your link shows one with a hitch and I assume yours doesn't have a hitch....thanks
This was royal xj's old bumper, I'll take some pics today for you. Was going to install on my xj but I bought another with a bumper on it so I'm scrapping this project.
No hitch in the rear bumper.
Ok sounds good, I'm off till the 6th, but baby on the way so let me know what would be good for you, I think you have got to somewhere around an hour away
