CURRIE STEERING ON SALE $150 OFF - CURRECTLYNC - TJ/LJ/XJ/MJ HEAVY DUTY STEERING KIT
RWKHausSupply
From today till the End of September
Currie's Heavy Duty Steering Kit is on sale
SAVE $150
GO HERE TO SEE & ORDER THIS KIT
Simply Use Discount Code CE-150 when you check out.
This is the ONLY bolt on kit that addresses all the Issues of the stock steering. This kit is currently and has been used on Race Jeeps for Longer than Any Other after market steering kit still being made. And there is a reason for that. No alterations are needed for this kit to be bolted on your lifted Jeep.
The Currie Currectlync heavy duty tie rod and drag link system for TJ, LJ, XJ, MJ and ZJ vehicles features, a 1 1/4 inch diameter forged alloy drag link, and 1 1/4 inch solid alloy steel tie rod bar that is bored and threaded on the ends. All 7/8 inch thread tie rod ends with boots are included as well as the Currie heavy duty steering stabilizer bracket. This unit is a direct replacement for the stock parts. No modifications or machining to any part of the vehicle is necessary. This unit is rated at 200 per cent stronger than the stock components. Note: This unit is designed to be used on vehicles with 4 inches of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2 inch bump stop, over stock. Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment.
Fits:
1997-2006 Jeep Wrangler TJ
2004-2006 Jeep Wrangler LJ Unlimited
1984-2001 Jeep Cherokee XJ
1986-1992 Jeep Comanche MJ
1993-1998 Jeep Grand Cherokee ZJ
Details:
TJ/LJ/XJ/MJ/ZJ Currectlync Steering System
1 1/4 Inch Diameter Forged Alloy Drag Link
1 1/4 Inch Solid Alloy Steel Tie Rod Bar
All 7/8 Inch Thread Tie Rod Ends With Boots
Includes Zinc Plated Heavy Duty Steering Stabilizer Bracket
Designed To Be Used On Vehicles With 4 Inches Of Lift - See exception above.
Black Powdercoat Finish
Sold As A Kit
