Oil Fill cap
TRCM
Newport News,VA
Anyone got any suggestions for a new oil filler cap ?
Hopefully a 1 piece version that does not ratchet ?
Mine is a bear to remove if the engine is at all warm, and I am afraid it won't be long before it breaks.
Both of my jeeps had this problem I just pryed the top off of them and just use the threaded part of the cap some say you can j b weld the top to the bottom
but idk for sure.
but idk for sure.
This works ^.
Stant 10111 oil fill cap worked on mine, no ratchet.
Yep
Only $7.37 shipped off of eBay
I replaced my broken one with the Stant. It works but I don't like it. Being older my hands don't work as well as they used to. With the shallowness of it makes grabbing it to turn tough for me. Also I make sure I never put it on too tight. Had to use pliers to grab it and take it off first time I made that mistake. I would prefer the factory one.
the top broke of off mine...solution was to just drill 3 holes on the edge (in the indent areas) and put screws into it. Works perfectly fine now.
