I play a musical instrument, and its called a jeep
Blind Driver
West Chester Pa
So my family likes to mock the fact that my car makes more noise than they can handle. So I figured I would start up a thread to post all the weird noises your jeep makes.
I'll start:
Tires rumble
rear shocks pop on bumps
roof rack whistles at highway speed
Mount for my OBA kit has a loose bolt that likes to jingle
handles to roof rack storage ammo can rattle
Banjo.
I'll admit it, I was expecting techno jeep.
tires rumble (they never used to, till I hammered it so hard I smoked the tires... while snow wheeling)
driver side balljoints clunk
can hear everything through the holes in the floor in the trunk
swaybar links clunk if connected, at least till the bolts fall out, then they swing in the wind and clunk all the time
power steering pump whines
doors clunk and squeak
exhaust grinds on the crossmember and leaf spring
fuel pump whines
rear driveshaft turned the whole jeep into a massage chair because I need an SYE
e-fan rubs on the PS pump pulley when it (tries to) run
fan shroud broke, so the fan hits it if I throttle up
... I think my horn and headlight buzzer are the only things that DON'T make noise, they both broke
doors squeek when opened (push on the front quarter panels too)
power steering pump wines on occasion
belt screems constantly
that's all i can think of right now, haha
kastein, you have/had a light buzzer? not sure if the 89 xj had one or not (if it did it don't work now! lol)
i actually came in here cause it has been a while since i saw tecno jeep, and i was hoping to watch it :D
