Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Prev Previous Post   Next Post Next
Old 04-10-2005
cracker's Avatar
cracker cracker is offline
NAXJA Minion
Pro Comp Lift Kit 'almost New' FOR SALE!
(THIS WAS PREVIOUSLY POSTED IN THE SOCAL CHAPTER FORUM)
I have an almost new Pro Comp 3" lift kit. Forget the Budget boost stuff, get this 'almost new' kit for a fraction of the price of a new one. I installed this on my XJ for 3 months before I went to a 7" long arm set up. The kit's parts are:
(2) Sway bar links
(2) Sway bar mounts
(2) 12mm ID sleeves
(2) 3/8" ID sleeves
(4) Hourglass bushings
(2) Sway bar adapter sleeves
(2) 3/8" x 1 1/2" USS Gd 5 bolts
(2) 3/8" x 2 1/2" USS Gd 5 bolts
(4) 3/8" USS Locknuts
(4) 3/8" SAE Flat washers
(2) 3/8" USS Hardened Flat washers
(4) UBolts (one brand new)
(8) UBolt nuts (missing one)
(8) Washers
(2) Add a Leafs approx 22" (installed in leaf pack)
(4) 5 1/2" bolts (installed in leaf pack)
(4) Nuts (installed in leaf pack)
(2) 4 degree shims (installed in leaf pack/Never came in the lift)
(2) Front coil springs
(2) Front Lower control arms
(8) Red control arm bushings
(4) .75 x .50 x 2.625 sleeves
(1) Track bar drop bracket
(1) 7/8" x 1.25" spacer
(1) 7/16" x 2.5" USS Gr 5 Hex bolt (missing)
(1) 3/8" x 1" USS Gr 8 Hex bolt (missing)
(2) 7/16" SAE flat washers (missing)
(2) 3/8" SAE hardened flat washers
(8) 5/8" SAE flat washers
(1) 7/16" USS Nyloc nut (missing)
(1) 3/8" USS stover nut (missing)
(4) ES3000 Shocks (2 fr and 2 rear)
There might be a couple of more bolts missing but as far as I know it should be complete. Nothing major is missing. Just a small trip to the hardware store for some hardened bolts will take care of things.
This kit also includes a leaf pack with the ADD-A-LEAF installed AND a 4 degree shim (which did not come in the Pro Comp Lift) to correct the rear pinion angle. I will ALSO include two other leaf packs (from a full size Chevy) that you can mix and match the leafs together with the XJ pack to play with the height of the rear (so it doesn't sag/ I found that the ADD-A-LEAF didn't give me the height I wanted/needed).
$300 OBO
I REALLY DO NOT WANT TO SHIP!!! The leafs are HEAVY! LOCAL PICKUP IS PREFERED! If there must be freight, buyer will have to pay actual freight.
If it must be shipped, and one does not want the leaf pack(s), I can remove the add-a-leafs and shims and send those to save a boat-load on freight to the buyer.
Thanks
Cracker
XJ lift KIT crazy4mopar Sierra Chapter 21 12-11-2006 21:14
bigger lift, now what??? tommy1102 Modified Tech Discussion 9 03-09-2005 08:15
another lift kit question... KinesthesiaDrums Modified Tech Discussion 11 10-01-2004 07:32
Pro Comp Radial Mud-Terrain Tire and any ideas for a lift Z22_Z33 Modified Tech Discussion 5 06-06-2004 12:10
TŪV- approved lift kit? bucholzi Modified Tech Discussion 4 02-09-2004 04:17
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
