Old November 14th, 2017, 09:57
sm465np205 sm465np205 is offline
5.3 swap
New member here figured I'd share my Jeep I just got done installing an lm7 in
Sent from my XT1565 using Tapatalk
Old November 14th, 2017, 11:33
5.3 swap
4.0 coming out
Old November 14th, 2017, 11:36
5.3 swap
Engine getting prepped for install
Old November 14th, 2017, 11:38
5.3 swap
Novak headers, Novak slave retrofit, Novak ax15 to Chevy bell adapter, Novak motor mounts
Old November 14th, 2017, 11:41
5.3 swap
Initial install and wiring nightmare, Novak radiator
Old November 14th, 2017, 11:44
5.3 swap
Exhaust system getting built and a couple mufflers I can quickly interchange with the whole system using v bands
Old November 14th, 2017, 11:49
5.3 swap
Wiring all wrapped up and Dakota digital vss interface to convert the Chrysler speed signal to 128k ppm LS compatible
Old November 14th, 2017, 16:27
indian's Avatar
indian indian is offline
Re: 5.3 swap
good luck with the swap. this engine will make you many smiles while driving
Old November 14th, 2017, 21:54
clydefrog's Avatar
clydefrog clydefrog is offline
Re: 5.3 swap
Lookin' good!
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old November 15th, 2017, 00:10
TRCM's Avatar
TRCM TRCM is offline
Re: 5.3 swap
What did you do to get the engine so low....most swaps I see have to cut the hood
Old November 15th, 2017, 00:34
indian's Avatar
Re: 5.3 swap
you have to use LS1 style intake, truck intake is too tall
sm465np205 - I want to see the first ride video with the manual trans
Old November 15th, 2017, 01:33
TRCM's Avatar
Re: 5.3 swap
manual trans & stock axles.......
Old November 15th, 2017, 06:04
5.3 swap
Yeah I'll have to rig the GoPro up on it. Been driving it now for a couple weeks. The thing is an absolute rocket ship and it's not even tuned yet. 4.10s and 35s. Could not be happier that I was able to keep my trans
Old November 15th, 2017, 06:16
5.3 swap
To stay under the hood you need a car intake as mentioned and the Corvette accessory drive. The F body drive puts the alternator in interference with the steering gear. I bought the Vette water pump new, used Pontiac G8 balancer (same belt spacing as a Vette), and a Holley alternator/power steering bracket which is a copy of the factory bracket. What's cool is the Vette drive takes a type 2 power steering pump, not a Saginaw like the truck drive. I was able to slightly modify the WJ v8 pump I had on the 4.0 and use it on this bracket. Currently has a 105 amp alternator but the optional 140 amp unit bolts right up
Old November 15th, 2017, 06:38
Vintage Smoke Vintage Smoke is offline
Re: 5.3 swap
Subscribed! Nice work. Ill be starting a similar swap soon. I have a pristine rust free 2000 2 door, complete 2002 Tahoe donating the engine, SM465, 203/205 doubler, and a D70/D60 combo to swap in. You have already given me some insight to figure out some of the challenges.
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 08:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
