Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > 35th Anniversary Celebration! Moab, Utah
35th Anniversary Celebration! Moab, Utah Come join NAXJA at the 35th Anniversary Celebration of the XJ. Moab, Utah. October 9-13, 2018
View Poll Results: Driving or towing
towing 22 78.57%
driving 6 21.43%
other? explain 0 0%
Voters: 28. You may not vote on this poll
  #31
Old November 3rd, 2017, 12:49
Nimrod's Avatar
Nimrod Nimrod is offline
Livin' the dream
Re: Driving VS Towing
I looked into it a couple of years ago. The couple of places I checked had pretty low tow weight limits built into the rental agreement. Basically, they'd let you flat tow a Yugo. Enforcement, of course, is pretty much on the honor system . . . unless an accident were to occur. I opted not to take that chance.
A whole lotta things that I never done. But I ain't never had too much fun!
Bill Kirchen and Billy C. Farlow, as recorded by Commander Cody and his Lost Planet Airmen
Old November 3rd, 2017, 15:03
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Fill the tires with helium, duh.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old November 4th, 2017, 17:30
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Noah and I are looking at options. In theory, we have one Dodge 2500 diesel for a tow pig, but we need to haul a 20' travel trailer, Gomer and Lil' Gomer. Not sure the 2500 can tow all three pieces.
I would certainly consider shipping the Jeeps. Having two makes it more challenging. I'd also consider going in with someone on a group "rent", or getting a deal on a car carrier.
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2019
Not a member? Become one today, and help support YOUR club.
Old November 4th, 2017, 17:56
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Originally Posted by two_door_rob View Post
Chicago to Moab and back cost me around $800 in gas. That's towing the Jeep behind a 2500 gasser. I think the gas was half that when I drove the Jeep out there.
And this is basically the reason I trust to drive my Jeep there. Worst case scenario, I drive your Jeep home and you pull mine, although I would spend more in gas than the 2500
Sent from my SM-G955U1 using Tapatalk
Old November 6th, 2017, 02:16
ericsennert's Avatar
ericsennert ericsennert is offline
I plan to trailer mine down. The other two guys are driving theirs.
Old November 9th, 2017, 18:33
twinhauler's Avatar
twinhauler twinhauler is offline
I would like to get a tow rig and trailer by then but we will see. If not I will drive because I am going to Moab for this event. It between 920-990 miles one way. I am looking forward to it.
Old November 17th, 2017, 09:46
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
I drove from CA in 2008, but with the longer drive from TX, plus the diesel canyon in my driveway, I think towing is the way to go
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old November 23rd, 2017, 22:15
waxer's Avatar
waxer waxer is offline
We will be driving our Class A and flat towing our XJ from Lakewood, CA. We've flat towed to other camp spots just fine and this one will be a bit longer, but totally doable.
Old December 4th, 2017, 14:15
peterjford peterjford is offline
Originally Posted by peterjford View Post
We will be taking both the XJ and the Suburban. I think the Suburban would be maxed out loaded down with camping gear and towing the XJ on a fullsize car trailer, so I might drive the Jeep and Shannon drive the Suburban. Or we might flat tow the XJ. Both have to get there and both have to come home, we will figure out something.
Apparently our "whimpy" 2006 Suburban is rated to tow 7600 lbs, more than enough for the XJ on a trailer.... so who has a trailer the will hold a XJ and isn't using it in Oct 2018?
Peter J. Ford
Purple Is The New Chrome
KK6QQV
Old December 4th, 2017, 14:22
Coach Bruce's Avatar
Coach Bruce Coach Bruce is offline
See if you can find two or three of them. I'm not sure my over ten year old BFGs will make it that far!
Old December 12th, 2017, 13:15
x-jay vision x-jay vision is offline
Anyone else from the Albuquerque area going? Maybe figuring we could work a carpool or something
Rate This Thread:
Towing with an XJ Nik Tow Rigs and Trailers 17 March 30th, 2010 13:02
XJ towing XJ AJTorris OEM Tech Discussion 9 January 5th, 2010 14:57
towing ? konoff1998 OEM Tech Discussion 16 September 5th, 2008 23:40
Flat Towing/Dolly Towing/Lockers ? 2xtreme Modified Tech Discussion 14 October 9th, 2004 06:33
Who's driving and who's towing their XJ? XJguy 2003 20th Anniversary Celebration! Moab, Utah 52 September 16th, 2003 17:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
